Trouble code p1415??
Discussion in 'General Chevy & GM Tech Questions' started by Blakjax98, Aug 17, 2013.
  1. Blakjax98
    Blakjax98 Member
    Hi guys, so the "Service Engine Soon" light came on last week and i pulled a P1415 code "Air Pump Circuit". Has anyone had this before and know what the issue could be??
  2. 99'HEARTBEAT
    Trouble Code.....P1415 Indicates a problem with the A.I.R. system. This Code is a common indicator of an A.I.R. injector problem.......The 2-Check Valves, that the secondary Air Pipe Plugs into the exhaust manifolds, that cause this Trouble Code to come up, It is worth changing both of them because if one fails the other is not far behind. It is also worth replacing the factory hose clamp with a regular one,
    P1415 Indicates its the Check Valve on Bank 1.....which on the Driver Side, needs to be replaced(See Diagram)
    Both Check Valves on the Driver and Passenger-side are Number #5 in the Diagram.
    [​IMG]
    EDIT:.....I should Mention, that this Diagram of the Intake manifold, is for a 5.3 Liter.
  3. Blakjax98
    Blakjax98 Member
    This is exactly what I needed. How much are the valves??
  4. 99'HEARTBEAT
    The Cost for it Each Check Valve is around, $20.00/$25.00 depending on who you buy them from.
    BTW....where a bout's are you in Calif.??
  5. Blakjax98
    Blakjax98 Member
    Santa Clarita
