Troubleshooting a P0307 code
Discussion in 'GM Powertrain' started by hblock72, Oct 25, 2009.
  1. hblock72
    hblock72 New Member
    I have a 2007 new body style silverado w/ the 5.3 engine that stated missing on the way home from work the other day. Check engine light came on with a P0307 cylinder #7 misfire code. In successive order, I've done the following clearing the code between each step: 1) swapped #5 and #7 spark plug 2) swapped #5 and #7 plug wire and 3) swapped #5 and #7 coil. After each swap the same P0307 code came back. I assumed I'd find the bad part and a P0305 would come up, but no such luck. So i'm about out of options. Does anybody have any ideas? The plug seemed to have a good bit of fuel on it when I pulled it, so i'm doubtful it's the injector, but who knows. Wondering if it's something mechanical in that cylinder. Again, anyone have any ideas? Thanks.
  2. Jimmiee
    I'll bet it's the injector. A small piece of debris in there is all it takes.
  3. hblock72
    hblock72 New Member
    Finally gave up and took it to the dealership. They found it had a bad lifter. The good news is it's covered under the 100k powertrain warranty. The bad news is it's got a bad lifter. Oh well, life goes on.
