truch leveling info
Discussion in 'General Chevy & GM Tech Questions' started by dewfamily, May 16, 2012.
  1. dewfamily
    dewfamily New Member
    I have a 2000 Silverado reg cab/short bed. The po had put 265/70/17 tires on it. It had the stock ride height. I bought a set of shackles off ebay and 'lowered' it about 2 inches. It still seems a little high in the back end. What can I do to get it level?
  2. dewfamily
    anyone? Could use some help. Do I need to raise the front alittle. If so, how?
  3. Jaele
    Jaele Rockstar 100 Posts
    You can remove the shackles and purchase a leveling kit for the front end
  4. Burden33
    You can order another shackle or remove the blocks in the rear or do like he said and run a smal leveling kit
  5. dewfamily
    what kind of small leveling kit?
  6. dewfamily
    truck leveling
    Any help? What kind of leveling kit?
  7. UpsetProps
    UpsetProps Member 2 Years 100 Posts
    1. Park on level ground
    2. Make sure box is empty
    3. Measure from the center on your rear wheel at the axle up to the bottom of the wheel well
    4. Measure from the center on your front wheel at the axle up to the bottom of the wheel well
    5. Subtract the measurements to find the difference
    6. Purchase a front end levelling kit that matches the difference
    ex: if you measure 42" rear and 40" front you need a 2" front leveling kit. (I just made these numbers up, don't use them as a guide.)
