truck shopping - what drivetrain? V8 vs V6: 4x4 trans/front diff (reg cab short box)
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by KingAries, Nov 13, 2013.
  1. KingAries
    KingAries New Member
    Just checking to make sure the V6 and V8 4x4 regular cab trucks use different transmissions, transfer cases, and front diff/axles?
    I'm looking to pick up a project truck, will be doing a FI engine swap, and wanted to make sure I wouldn't be saving money and time by finding a V6 truck instead?
    Mostly concerned with the strength of the front diff/axles, then transfer case, and trans. manual preferred over auto also.
    I'm hoping an expert knows these tech specs pretty well and can post them in this thread for me.... thanks :great:
  2. Conlan Rose
    Depending on the year they may use a different tranny, but they use the same front axle and most times the same rear end. T-case is dependent on vehicle options like lever shift 4x4 or electronic
  3. KingAries
    Awesome, thank you. So, the same front IFS axles/diff on all vehicles? Good to know. Another question - Any strength/weakness issues with the lever vs electronic T-cases?
  4. Conlan Rose
    Both are very solid, but sometimes the electronic and have issues if say the switch stops working or the shift motor dies. The lever is so basic that it rarely has issues, but its less convenient. But yes exact same front diff on all the IFS trucks and suvs from 1988 to 2007 at least
  5. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    I'd go with the manual lever 4wd, that way you know its in, no electronic bs to break down or hesistation when engaging the front wheels.
    And what type of truck are you wanting to build? If your going for a lifted trail irmud rig you'll probably wants solid front axle over the ifs.
    And again depending what year truck you want you might as well get the v8,or if possible the motor your lookin to swap from the get go. With these newer v6 engines being stout as they are they easily compare to the old 305s and even some 350s....but the fuel of these v6 engines really isn't any better than 5.3 v8. And most would take the 5.3 and 6.0 over the old sbc. Honestly I'd hook my 4.8 up against a canned 350 and not think twice about it. And you can pick up used 6.0 with harness and ecm for $750-1000 all day long at junkyards.
  6. KingAries
    Yeah good point on the electronics. It will be a road race truck, slightly lowered, not lifted. I'll probably try to find a V8 truck to make everything easier right off the bat.
  7. clgoch187
    And you want 4wd for that? The ss are Awd and have the 6.0 but they are a little harder to find and your gonna pay a bit more...also they were all ec sb. I'd try finding a scsb work truck, most are 5.3 and fairly cheap.
  8. KingAries
    Sure do. I don't like traction issues in trucks with big power, so awd/4x4 it is. And it's not going to be a drag truck. It will be a hot rod for the street and track, not a daily driver. Must be scsb for this project though
    - - - Updated - - -
    Here's a good question - What front drivetrain are the SS trucks using? Same diff/axles? transfer case and trans?
  9. clgoch187
    Far as I know the only difference is the transfer case they still have the 4l60 transmission. I'd try picking up a t56 manual trans
