truck will not run
Discussion in 'GM Electrical Tech' started by 97mud, Feb 6, 2013.
  1. 97mud
    97mud New Member
    I have a 97 chevy k1500 5.7L 350
    im getting spark and fuel with no issues but it will not run i spray starter fluid in and it cranks over till all the starter fluid is gone then dies on me i need help
    i already replaced the fuel filter
  2. RayVoy
    If it runs with starter fluid, you are not getting fuel.
    Fuel pump relay, or the pump (can you hear the pump operate?)
    Edit: or, no fuel in tank.
  3. 97mud
    97mud New Member
    yes its getting fuel to the fuel rail and its comes out the injecters i can smell it from the exhaust
    but will not run could it be that im not getting enouch psi?
  4. MrShorty
    I'm not sure it is fair to say "it is for sure getting fuel" until you've checked the fuel pressure. If you haven't yet put a fuel pressure gauge on it, then that is the next step.
  5. 97mud
    97mud New Member
    the psi should be around 60 correct
  6. MrShorty
    published spec is 60-66 psi. When I had trouble with mine a few months ago, 45-50 appeared to be near the minimum needed to start.
