Truck won't blow heat down by floor
Discussion in 'General Chevy & GM Tech Questions' started by Corso, Jan 3, 2012.
  1. Corso
    Corso Rockstar
    Hi everyone. Really digging this site, lots of helpful info. Hopefully someone can shed some light for me on this one.
    I recently noticed that my '00 Silverado will not blow heat from the low vents down by your feet. Up top it is fine, nice and hot and strong. Down by the feet, nothing.
  2. fooddaman
    fooddaman New Member
    You might check all of your vacuum hoses to make sure they are connected and/or not cracked. I had a 2000 GMC astro van that did something similar with the AC blowing up out of the defrost, but not the vents/floor.
  3. grape2
    grape2 Member
    My Suburban was doing that last year and the blend doors were binding and had to be replaced. Also, one actuator was bad not working the blend door.
  4. Corso
    Corso Rockstar
    Interesting. Was this a difficult job? If you didnt do it yourself, do you remember what it cost to have fixed?
  5. vncj96
    you can get to your blend door easily, it sits right above the transmission hump, just a couple screws and it will open it up and you can see what it is or isnt doing when you switch it to the floor vents. there is a gasket that helps it seal into its different positions, most of the time that had torn and is caught up in the door
  6. Corso
    Corso Rockstar
    Wow, that sounds hopeful. I will investigate tonight. Thanks.
  7. donl
    donl Rockstar 100 Posts
    I have a friend with a 2008 K2500 that just got his blend door problem fixed for the 2nd time. Also his fan would only run on high so it took a resistor/relay worth about $300 to get it working right. $575 total to get it fixed at a GM dealership.
  8. vncj96
    Your friend got ripped off, putting in a new resistor for the fan is easy and cheap to take care of your self, and all you need to know how to do is turn a screwdriver
  9. sstoner911
    [sarcasm]What? Someone ripped of by a dealership? Noooo waaaay! [/sarcasm]
    Coroso did the advice vncj96 gave you help? Usually thats the source of the problem you described.
  10. Corso
    Corso Rockstar
    I haven't had a chance to really get into it. My truck has the center console that runs up under the dash. I looked at it briefly today and it looks like I will have to remove the console to really get at it.
