truck wont shift out of 2nd
Discussion in 'GM Powertrain' started by Sicksilverado781, Apr 3, 2010.
  1. Sicksilverado781
    Sicksilverado781 New Member
    so all of a sudden my truck wont shift out of 2nd i didnt hear any noises or anything.i dont really know much about transmissions so someone please help truck is a 03 1500 5.3
  2. Sicksilverado781
    it has 125,xxx never had any problems with it.
  3. Sicksilverado781
    the service 4wd has come on a few times when it was really cold other than that i cant think of anything
  4. rustyk2
    rustyk2 Rockstar 4 Years 500 Posts
    Sounds like the problem I'm having, My 1988 drops third and will not go back. Jimmie is helping me, He is most learned in transmissions and their workings. My problem turned out to be a broken plastic piece under the valve body. Why GM uses plastic or composite for this stuff is beyond me. Check out my thread in this forum, it might be the same issue. Good Luck.
  5. Sicksilverado781
    thanks for the help.mine didnt make any noises or anything it just all of a sudden stopped working
  6. rustyk2
    Mine made no noise, just dropped the gear.I posted a pic of what went wrong on my thread, page three. Also Jimmie was accurate in what went wrong.
  7. murdog94
    IS the CEL on?? Sounds like your tranny is in safe mode.
  8. Loggerhead Mike
    x2, we call it limp home mode
    could be a number of things. need to get the codes scanned and watch the tranny data
  9. Sicksilverado781
    thanks for the help
  10. AMC NUTZ
    AMC NUTZ New Member
    Could be a host of things... Ive had all of em on different veihicles. Does your speedo work? Does it start in first then lock in 2nd or always in 2nd? We call it limp mode. Check yours trans fluid and see if it is red/plum/rust/or black in color. does it have bubbles and appear copper in color when warm? Have you had any work done recently? are you getting any codes thrown? is the CEL on?
    Id be happy to point you in the right direction if you can answer some of these q's
