    Join Today ~ It's Free
trying to drain the radiator
Discussion in 'General Chevy & GM Tech Questions' started by moxnix92, Jul 11, 2009.
  1. moxnix92
    moxnix92 New Member
    I decided to do a radiator flush on my 94 Sierra, which I have never done before on this truck. I'm lying on my back looking up and I can't even see the bottom of the radiator let alone find the drain. Is there something I need to remove? Like the front skid plate? I hate taking stuff apart and then finding out the answer was right in front of me !
    TIA
    Steve
  2. 2COR517
    Usually you can see and reach them from the top side. It's little wing nut looking deal, with sort of a tube on it so you can hook on a piece of 3/8 hose.
  3. moxnix92
    moxnix92 New Member
    On the driver's side ?
  4. 2COR517
    I think so. Ready for bed now, I'll check tomorrow
  5. Mean_Green_95
    If I were you, I would take off the lower radiator hose at the radiator instead of trying to use the actual drain plug. I've heard a few stories of people trying to open the the drain plug and it braking off, resulting in a new radiator. Also, look into replacing any and all hose while you're at it, along with you belt. Might as well replace everything while you're in there now...
  6. 2COR517
    His ideas are good. There are also two block drains, down near the oil pan. I havn't pulled block drains since I had my 81 almost 15 years ago. They don't come out easy, but it's the only way to really drain your entire system. 5/8 socket with long breaker bar if I remember correctly. Truthfully, you'll probably get your time back, because everytime you add water, it will still turn green.
  7. moxnix92
    moxnix92 New Member
    Thanks- I found it down by the bottom on the drivers side. The guy who owned the truck before me had a second battery installed on that side, so I had to remove that before I could see anything. I also had to pull the long blank cylindrical thing with two hoses going in to it- I guess it's some sort of smog device (do I need that?). I also agree that the valve seems kind of fragile- I was expecting an old fashioned metal valve. So I got everything drained, and a tube would have been nice because it was messy. I ran the flush and water through and had to stop there because it was getting late. I'll drain that this morning and add the final coolant mix.
    Steve
  8. 2COR517
    Can you post a pic of the unknown device?
  9. moxnix92
    moxnix92 New Member
    The truck seems to run fine when it's disconnected, but I put it back anyway.
    Thanks
  10. 2COR517
    Vapor canister. You want that on there. No impact to performance.
