Tuff Country lift kit?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by 99monguse, Jan 6, 2010.
  1. 99monguse
    99monguse Rockstar
  2. 94bluebeast
    94bluebeast New Member
    lift kit
    Have you plowed before? I wouldn't recommend using a plow with a lifted truck for a couple of reasons and hopefully you'll see why ( I plow @ Newark Airport for Continental Airlines Gates 1 through 96).
    One, Plow hook-up points will no longer line up as mounts are attached to frame and now your frame is multiple inches higher do to lift kit.
    Two, It's hard enough to see the plow when its down and what its pushing and since you want to lift it you probably won't see it in the up position (the lifting arm only lifts so high) at all which is a danger to you and to other divers on the road.
    There are a couple of other variables that could cause problems, I only listed two in hoping you make a "smart and safe" choice. You could with some custom fabrication and lotsssssssss of money make this all work, but come on do any of us have that kind of dough?? Good luck and best wishes.. Ray Z.....
