turn signal fuse
Discussion in 'General Chevy & GM Tech Questions' started by blazerguy, Nov 8, 2009.
  1. blazerguy
    blazerguy New Member
    i have a 96 s10 blazer and the turn signal fuse blows everytime i turn the key on. we replaced the turn signal switch and it still does thwe same thing. please help.
  2. unplugged
    Try taking out one bulb at a time until the fuse stops blowing. That should help you isolate the problem between the front and the rear. Then you should be able to narrow it down between the left/right. Either a socket is shorted or the harness.
    Does it blow when you step on the brake pedal?
    How about when you turn the hazards on?
  3. blazerguy
    tried doing that and it still blows. we removed the front harness and it still blew. hazartds work and brake lights work when fusee is blown. every time you replace the fuse and turn the key on it blows. what about the brake switch? could that cause it?
