Turn Signal problem.. doesn't pulse..
Discussion in 'General Chevy & GM Tech Questions' started by Falcone, Oct 29, 2009.
  1. Falcone
    Falcone Rockstar 100 Posts
    First off its a 92 sonoma reg cab short box 2.8L and well my left turn signal is messed up now. At first I thought it was just because the bulb was burnt out so I replaced that. Didn't cure it, checked the fuse, looks to be intact and fine. So now I got no no clue. The indicator has been slightly (broken) since I picked up the truck last year, meaning it won't self cancelle and just stays on even after I've completed my left turn. But now the bliner just lights up and stays on, it doesn't blink.. Any input guys?
  2. vncj96
    pull the bulbs out of the taillight and check the actual socket, if it is brown or black inside it is fried.
  3. Falcone
    the socket looked fine when I changed it, the bulb lights up, but it just doesn't flash for signaling.
  4. vncj96
    Swap the bulbs just to double that its not another bad bulb.
  5. Loggerhead Mike
    sounds like your switch may be bad
