U-Joint Replacement
Discussion in 'General Chevy & GM Tech Questions' started by MightyMax, Jun 3, 2010.
  1. MightyMax
    MightyMax Rockstar 100 Posts
    '91 Silverado, 350 V8 5.7L
    Multi joint drive shaft.
    I shreeded the rear U-joint the other night (the one connecting to the rear axle).
    Now I am haveing a really hard time trying to get what I think is the proper replacement part on this thing.
    The one I am replacing appears to have all "Inside Lock-Ups"
    But the one that I got from Advance Auto looks to be similar to my bad one, but the Lock-Ups are outside, not inside.
    If you look at Advance Auto's Site, it is the Neapco U-joint, P/N: 2-4800
    I had purchased the 2-3011BF originially, but the bearings have a larger diameter then the one that went bad.
    Where as the 2-4800 U-joint, seems to have a similar diameter....but like I said the Lock-ups are different.
    Anyone have any advice on this?
  2. murdog94
    To be honest with you I just had my rear driveshaft rebuilt.. After having the same bearing problem as you are.. I never did get it figured out i let the shop that gets the work that i dont want to do handle it..
  3. MightyMax
    I was able to talk with a Tech Support person at Neapco.
    Looks like for me I need their 2-3011 U-joint.
    So I will get that one and try him.
  4. vncj96
    Not sure when GM started it, but they use a plastic injection for the factory retainers for the OE u-joints, so that plastic has to be melted out with a torch, a heat gun just doesnt seem to get it hot enough.
  5. tbplus10
    Plastic injection on the U-joints started sometime in the early 80's and your right it needs a torch to melt it out.
    Beating or pressing the bearing out will only bend the D/S ears.
  6. MightyMax
    I am guessing they stopped doing that, because I was able to drive out the two bearings that were still in the drive shaft.
    The other two were shredded when the joint broke :D
    So that made getting the thing a part a lot easier.
    The 2-3011 was the u-joint for my truck.
    Got it put in and driveshaft back in place. Working great.
    There has been a squeaking noise for a while, which I thought might be the rear brakes.
    But it appears it was the U-joint going bad......
    The squeaky noise is now gone.
    So was able to kill 2 birds w/ one stone on this job. Which is always nice.
