under hood storage??
Discussion in 'The Coffee Shop ~ Chit Chat' started by arcanap51, Nov 9, 2007.
  1. arcanap51
    arcanap51 New Member
    Does any one know if there is an underhood storage compartment available (factory or aftermarket)for a 2001 silverado? I know that they used to be available in the older style where the 2nd battery would go...
  2. unplugged
    I don't know of any. On my burb I picked up some surplus ammo cases. They are tough, watertight and cheap. I plan to make a bracket and attach them to the frame rails for storage of some recovery gear that I don't use often enough to leave in the cabin.
    You might consider the same. Identify the spot underhood that you want to use and with some measurements, you could select from the available ammo cases.
  3. finalday7
    finalday7 Epic Member 5+ Years ROTM Winner 1000 Posts
    My 07 came with a space for a spare battery but as far as aftermarket I'm not sure but any shop should be able to weld you in some brackets. Or check with high end audio shops, they're putting dual batteries in alot of trucks. :great:
