update on power option issues...two down, two to go...
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by buckmeister2, Dec 1, 2012.
  1. buckmeister2
    buckmeister2 Rockstar 4 Years 100 Posts
    2001 silverado 1500 LT Z71 ex-cab stepside
    with help from you guys, the tow/haul is now working, as are the power mirrors. thanks, everyone (j cat put in extra help, thanks)
    still have no cruise control ("cruise" light goes on when button is pushed, but cruise does not engage), and no electronic 4x4 (dash icon does not light up, and 4wd is not engaging).
    there are no brake issues I am aware of, no warning lights, etc. the brakes do need replacement, but still working, without excess wear.
    i know the gm electronic 4wd has weak spots at the actuator and encoder, but I do not have a scanner, or the $ to go to GM to get it read so i can find out which it is. is one easier to change out than the other?
    anymore help out there?
    buckmeister
  2. RayVoy
    They do, and that problem might stop the indicator light from working. I'm not familiar with the 4x4 indicators in your style truck, I assume, from your description, that you should get an indicator light in the dash. Usually the "ok, we're in 4x4" signals should come from the transfer case control module (TCCM).
    Again, I don't know your truck, my last 2 trucks used a rotary switch to select 4x4, these switches often had dirty wipe contacts that could be cleaned, or, the switch could be replaced.
    The TCCM tells the electro-mechanical parts to go into 4x4 mode, it then receives a signal(s) tell it that each part is in place. Perhaps one of the parts is not in place and therefore, not returning the "ready" signal.
  3. j cat
    my guess is the ignition 1 fuse 10A is the problem. IGN 1 10A.
