Upper Ball Joint Replacement Help
Discussion in 'Maintenance & Upkeep' started by rileyjr16, Sep 11, 2012.
  1. rileyjr16
    So with 8 days left, I figured I'd replace my upper ball joints and get a alignment and have a normal driving truck for 4 or 5 more days.
    Here's my ledima:
    Should I buy the Ball Joints and Control Arms in one whole swoop (123$ with Moog Ball Joints) and replace them then get a alingment;
    Buy the Ball Joints only (25$-50$), take control arms and ball joints off, have a shop press them out and in ($40+-), then get an alignment;
    Or just have a shop do the whole thing ($$$-$$$.$$) + alignment ($$-$$$)? < don't want that since last time I'm sure I got wallet raped.
  2. dsfloyd
    I typically rent a ball joint press and just press them out. the swapping of the whole assembly would be easy and if your control arm bushings are fairly worn not a bad idea. If you are fairly handy do the work yourself and then take it in to have it aligned. I like a good older mechanic with old school gauges for alignment as they typically dial them in. The new laser racks usually the tech just gets it into a green area and goes on their way and is real expensive too. But as with anything finding a good shop is key.
  3. Pikey
    I agree with dsfloyd on this. I too rent the press and do it myself. IF I could afford the entire arm I would buy it for sure. I think The bushings for those run around $100 for all 8. But, the machine shop near me wants $40 each arm to press them in and out. So, in the long run it may be cheaper and less work to swap the entire arm out. I am not saying that your bushings are bad, they could be, but who knows? I tend to want to tighten everything up in the front end all at the same when I do that kind of work. (tie rods, ball joints, pitman arm, idler arm and bracket, and bushings) Plus when you put your lift kit on and the larger tires you may start eating ball joints. It will be nice to have the upper with a lifetime warranty that you can pull off yourself and replace instead of paying someone everytime
  4. dpeter
    I would lean hard toward replacing entire arm. Upwards of 90.00 just for parts and labor and all you have is a new ball joint. I mean really, if you take it to get joint pressed out , you've already removed the arm and have got it in your hand and so for less trouble, just put a new one in.
  5. rileyjr16
    Thanks guys. I did go buy 2 new assemblies, which turn out to be Master Pros for $201. I have too much on my plate today to even attempt it. Looking at the bushings I see some dry rot; however, it looks to be surface rot so I figured what the hell, the truck has 245,000 miles on it.
    Is there a special tool I will need to pop the ball joint from the steering knuckle or will some brute strength (body weight from my dad :lol:) and brains (again, from my dad) get them out?
  6. Pikey
    You can rent a ball joint separator from autozone for free. Just take the nut off and beat the fork in
  7. rileyjr16
    I'm just curious how one rents something for free :lol: :neutral:
    Thanks Pikey, I guess I'll go there tomorrow and rent one for free lol. Shouldn't take long huh?
  8. Pikey
    They make you pay for it with a credit card. Then when you return it they refund your money
  9. Pikey
    no it should not take that long. Just remember to spin the nuts off the bolts for the control arm not turning the bolts. The Bolts are cam bolts and if you spin them with an impact gun you can damage them.
  10. dsfloyd
    ball joint seperator is one way the other is to use a sledge hammer and hit the side of the knuckle where the ball joint rod goes through. Usually a few whacks and it pops out.
