v6 problem ~ Won't Start in Damp Weather - 1999 Chevy Silverado 4WD
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by larrybarr, Oct 30, 2013.
  1. larrybarr
    larrybarr New Member
    1999 Silverado v6 4x4 will not start in damp rainy weather. any ideals how to fix the problem, thanks
  2. SeanBurgandy
    SeanBurgandy New Member
    Have you checked your air filter? Maybe your filter is clogged/wet and is suffocating the motor? Will the motor turn over if you turn the key?
  3. larrybarr
    I had already disconnected the air filter, no luck with that. engine turns over good.
  4. Conlan Rose
    Have you checked your fuel pressure? It sounds like a fuel issue. That or one of the sensors on the intake side may not be reading right in damp conditions.
  5. stchman
    Maybe you have some ignition wire problems, give those a check out.
  6. j cat
    remove the distributor cap check the rotor / cap for water. wires on the v6 need to be routed as OEM built or you get these type problems.
  7. Pikey
    x2 on checking the cap and rotor. I had a truck in a week or so ago that had the same issue. He had taken it to multiple shops and a dealer. No one could figure it out. I talked him into letting me throw a cap, rotor, and wires on it. Problem solved. You can always pop the hood in a dark garage and spray the wires down with water. Look for arcing.
  8. j cat
    being the v6 engine this is the one where the ac lines drip condensation on the rotor cap ?
    if so these lines need be wrapped with tubing insulation to prevent this driping on distributor.
  9. jsmith4816
    jsmith4816 Rockstar 4 Years 100 Posts
    Does it crank? I had that issue about 5 years ago and it ended up being my started. There was this little rubber piece on the bottom that was gone. It allowed moisture in the starter making it not crank. May be something to look into.
  10. stchman
    I don't believe the NBS has a distributor cap. I thought GM went to distributorless ignition on the Silverado starting in 1999.
