very confused
Discussion in 'Chevy C/K Truck Forum' started by KmKing, Dec 9, 2009.
  1. KmKing
    KmKing New Member
    wife was driving 1980 Chev 3/4 ton down the road when it randomly backfired!
    causing a short out- or a short out caused the backfire not sure which-
    after the backfire all the electrical started freaking out- whipers were sporatic- blinkers
    were just as crazy- when i gave it gas it seemed short of power couldn't get going- even tho we
    were still moving.. i pulled the truck over for fear of ruining something. shut truck off
    towed it home... and now nothing stereo doesn't work- the only thing that works right now
    is that head liights- i checked all fuses they are fine! this truck has been perfect sum 1 pls help
    thanks "J"
  2. Get the test light out and start tracing, and check your gound cables.
  3. Tommygunz
    Tommygunz Rockstar
    I would check grounds first
  4. Project Reaper
    Project Reaper Rockstar 100 Posts
    ya it sounds like something major grounded out somewhere
  5. Dukeschevy
    Dukeschevy Rockstar 100 Posts
    Yeah, I also say its a ground, Make sure the bats terminals are tight and it's wires arent worn out somewhere, I think that would cause it. Good Luck
  6. dirtplay1975
    dirtplay1975 New Member
    also dont rule out the ignition switch almost everything effected runs thru it and they do go bad, i would check your voltage at the coil and see if its battery power. also u can check the heavy wires going into it the 10ga red ones, if it has batt power going in but not out its the switch.
  7. a4X42nv
    a4X42nv New Member
    Did you check all fusible links? I think the headlights are on a separate fusible link from your other electronics. That could be why only your headlights work. Just a thought, good luck!
  8. unplugged
    Sucks when the tunes don't work.
    Ok, but seriously......the test light thing is the best way. Start at the battery and work your way to the fuse panel. You will probably find a blown fusible link. :glasses:
    Keep us posted with what you find and come back if you have more questions.
