Vibration after transfer case replacement-new
Discussion in 'GM Powertrain' started by Family Force 6, Jul 19, 2012.
  1. Family Force 6
    Family Force 6 Rockstar 100 Posts
    A penny weighs about 3 grams. I should've taken a look in the shop to see what the balancing machine looked like. I saw where they took a weight off, put a new one in the same position from front to back, but moved it a few degrees around the radius of the shaft.
    This second place I took it to is called Bill's Driveshaft in Englewood, CO (with the classy tag line "You can't beat our shafts") and they do a ton of them. When I had my 71 Buick Electra they rebuilt that with a double-carden u-joint drive shaft and did a great job.
    I noticed the front shaft u-joints were pretty loose and probably need to be done soon. I'll be using these guys from now on for u-joint work.
