Want to fit a G80 in my '97 K2500 (C6P) & GT4 differential
Discussion in 'GM Powertrain' started by Bandolito, Jan 17, 2013.
  1. Bandolito
    Bandolito New Member
    My truck has the (RPO code) GT4 (3.73 rear axle DUP to 5X1) and I would like to upgrade it to a G80 locking differential.
    I believe I can get an Eaton MLocker to achieve this, but what all is entailed in such a conversion? Other than buying the MLocker, what else would need swapped out?
    Thanks in advance for any help!
  2. MrShorty
    Replacing the carrier like that is essentially the same thing as rebuilding the differential, minus buying a new ring and pinion. So you will essentially need a complete rebuild kit including bearings, seals, and shims. You will also need the tools, know-how, and patience for setting the gears up (including backlash, wear pattern, etc.).
    Are you married to the factory style locker (Eaton G80)? An often easier and cheaper option is to install an aftermarket "lunch-box" locker like the powertrax lockright or the Detroit EZ locker. These replace the "spider" gears inside the existing carrier to create the locking mechanism. Because these use the existing carrier, there's no need to set up the gears or the other stuff associated with carrier replacement.
  3. Pikey
    I would go with the DetroitEZ locker. But, be aware that the locker will only be as strong as the original carrier that you are installing the kit in. I would not go over a 33" tire with it.
