water noise
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by rkbonds1, Feb 10, 2012.
  1. rkbonds1
    rkbonds1 New Member
    In my 94 Suburban everytime I take off or stop it sounds like water is sloshing around somewhere between the transmission hump and the passenger side door around the dash area. What could be causing this? What can I do to fix it?
  2. Dana W
    It's condensation water in your A/C exchanger box up over the passenger footwell.. I bet it is also leaking out onto the carpet too. Check for wet under your floor mat.
    Find where the drain is for the thing, and run a wire coathanger up into it, see if that dislodges the shmugg that has clogged it up.
  3. Red Z71 Max
    Red Z71 Max Rockstar 3 Years ROTM Winner 1000 Posts
    DanaW is right. You may also want to pour a little bleach in there to kill any mold that may have accumulated in there. Thats stuff can be bad news and cause all kinds of respitory problems.
  4. 93SLESUB
    93SLESUB New Member
    My 93 Sub was making the same sloshing noise and also did it when turning sharply. I discovered that the heater core had become was air locked and bleeding the system fixed it.
