water spots?
Discussion in 'Detailing & Truck Care' started by freddie, Oct 14, 2012.
  1. freddie
    freddie Rockstar 100 Posts
    How do you remove water spots from windows and windshield?
  2. pilotj
    pilotj New Member
  3. Mook@Adams
    Mook@Adams New Member
    Freddie,
    There are a couple ways to go about removing hard water spots from your windshield. Sure, you can polish those away with some sort of Swirl and Haze Remover. You can also, and I've had good results with this, use .0000 steel wool and some denatured alcohol. This method is for GLASS only.
    Mook
    1 person likes this.
  4. The Heater
    The Heater Rockstar 100 Posts
    You can also use a detailing clay bar (and water). Do not rub hard.
    Diamondite makes a kit for removal of stains from auto glass. Check them out. I have had good luck using just plain old white vinegar if the spots are not too old. If they are old, you are looking at some kind of mild abrasive. Like what Diamondite sells.
  5. stchman
    Do you live in an area with real hard water? If yes, try a little bit of CLR on a cloth. Be careful not to get the CLR on your paint, and if you do you, rinse thoroughly and re-apply wax.
  6. K15 Blazer Guy
    i used the "softest" steel wool, and simple green, and just kinda polished the glass... then washed the whole truck... worked great!!
  7. TimTom64b
    Prep-sol... stuffs awesome.
  8. Blamer
    Blamer New Member
    Quite a couple solutions to go in relation to removing hard water spots out of your windshield. Sure, you can certainly polish individuals away with getting some sort of Swirl along with haze eliminator. You may also and We have had achievement with this particular usage.
  9. marksoldtowne
    marksoldtowne Member 1 Year
    hi freddie,
    Something simple would be mixing equal parts of distilled water & white vinegar.This mixture removes the water spot on the surface due to mineral deposit sitting on the surface. if you have etching below the surface then you will need a compound & a polish.
  10. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    RainX is the "Greatest" to repel water! JMHO
