Weird Climate Control Problem
Discussion in 'GM Electrical Tech' started by stephenjohler, Sep 25, 2012.
  1. stephenjohler
    stephenjohler New Member
    Okay so i got a 94 silverado. Ac and heat on the climate control. None of the buttons work at all. No display no nothing. But when i hit the parking lights on, i get illumination behind the actual buttons not the display. What the hell? Has anyone else had this problem?
  2. RayVoy
    Well, the lights your seeing are only the same as the dash lights, they come on with the head lights, just like the radio.
    You may have a blown fuse (look for those labeled HVAC), a loose connector at the back of the display unit, or a bad display unit. Check in the order I presented.
  3. stephenjohler
    Already did. I tore the whole truck apart and i cant figure it out. Checked all the fuses and relays. Don't know where to go from here. I put a test light on all the pins to the unit and its got power. I think i just need a good wiring diagram. I went to the junk yard and got a unit, same thing happens when i plug it in. But who knows if that was a good one.
