Weird issue with my headlights while using my horn?
Discussion in 'GM Electrical Tech' started by JRD761, Jan 8, 2013.
  1. JRD761
    JRD761 Rockstar 100 Posts
    Ok everyone, I have an unusual one for ya all..
    I have my 2012 Silverado with 5,000 miles on it.
    The other night while driving home, I had to use my horn. When I hit my horn, I realized my headlights cut off (for less than a second, but it was still noticeable).
    When I got home, I started hitting my horn again, and I found that something is randomly cutting off my headlights when I hit my horn. It doesn't always happen; I'd say it happens 1 out of 10 times I hit the horn. Does nothing to my fog lights, it's only screwing up both of my headlights.
    I'd love to take it to the dealer, but I have HID's on my headlights and fog lights and I'm sure they will blame the HID system. (Even though it uses all the stock wiring, and has no other wiring other than connecting into the stock plug). I might try this to throw in the stock bulbs and see if I get the same results..
    Has anyone heard of this before?
  2. PantheraUncia
    Sounds like a short somewhere. or maybe a relay in the wrong way.
  3. RayVoy
    It's a poor ground problem, recheck the HID ground wiring, and, or, the grounding for the body panel that the horn/headlights are using.
  4. Jamm3r
    The horn and the headlights share a common ground path. Check for a bad ground. Not sure how things are on the nnbs but on the nbs there's a fairly small ground wire that goes to the inner fender and indirectly to the radiator top support that, if loose or corroded, could explain something like this. You can trace grounds by putting the - of your voltmeter on the ground terminal of your battery and probing around with the + of the voltmeter on the chassis with the headlights on -- if there's more than a quarter of a volt anywhere you have a problem.
  5. Kady
    Put the stock bulbs back in and see if it fixes the problem.
  6. SurrealOne
    Yup, go back to stock bulbs and test. If the problem persists then leave them in and take it in under warranty. If not, then your HIDs and/or relays for them are the issue.
  7. Project1
    Project1 Rockstar 100 Posts
    Sounds like a grounding issue. But i would try like everyone recommended and put the stockers back in and see what happens. Could be an issue with the kit perhaps?
  8. shibby2oo8
    shibby2oo8 Member 2 Years 100 Posts
    Do you have hid with ballasts or just bulbs? Either way i would wire them with a relay to separte the factory circuit in case of a surge or short. That way is also easier to remove when taking it in to the dealer.
