    Join Today ~ It's Free
were can i get instructions...
Discussion in 'Audio, Video & Gadget Tech' started by stephen115, Jul 21, 2010.
Random Gallery Photos
  1. stephen115
    stephen115 New Member
    for installing a kicker amp and sub into my stock bose system?
  2. hundojoe
    hundojoe New Member 100 Posts
    All you need is a "line level convertor" you splice it into your rear speaker wires, then the convertor converts it to rca type cables. Its quit simple. You still have to run power wire and a source wire to your amp to turn on and off. Crutchfield sells them, here is two different versions depending if your going to run a 2 channel or 4 channel amp. Good Luck.
    Scosche LOC80
    2-channel line output converter
    Item #142LOC80
    2 speaker-level inputs
    2 RCA outputs
    rated for stereos up to 80 watts per channel $19.99
    Or
    Scosche SLC4
    Four-channel line output converter
    Item #142SLC4
    4 speaker-level inputs
    4 RCA outputs
    rated for stereos up to 80 watts per channel $24.99
