What are these wheels off of? Opinions needed.
Discussion in 'Chevy Truck Talk & GM News' started by choodock, Oct 1, 2012.
  1. choodock
    choodock New Member
    Colorado Wheels on a Tahoe
    I am thinking of putting these 17's on my truck to spend some time cleaning my other wheels. I am thining of running them on my 04 Tahoe then. Any thoughts?
  2. McClintoc
    Looks like they are off either a Colorado or Trailblazer. IMO, they might look OK on a Silverado but not a Tahoe.
  3. choodock
    choodock New Member
    Thanks for the reply. I did confirm that they are off a Colorado. I wanted a different look, but I think I am going to pass on these.
  4. pmf608
    Probably a good choice. They have high positive offset, so they would sit farther inside from the edge of the wheelwell than your stock wheels, and I haven't been able to confirm, but the bolt pattern might be 0.7mm smaller, which is enough to cause problems when it comes to wheels.
  5. choodock
    choodock New Member
    I think I may go with the 20 inch Silverado LTZ wheels for the Tahoe. I have a victory red NNBS crew cab with the Torq Thrust ST's and have had a terrrible time with vibration at highway speed. Someone told me these Tahoes and Silverados need hub centric wheels or they vibrate.
  6. 99'HEARTBEAT
    Peter....your Correct the Tahoe's have a Different(Larger)Bolt Pattern than the Colorado's,
    ***The Tahoe's have a............6 lug 5.5 inch or 139.7 mm High Offset
    ***The Colorado's have a.......6 lug 5.5 inch or 139 mm High Positive Offset
  7. McClintoc
    Most vehicles need hub-centric wheels or they'll vibrate. If you get get wheels that aren't hub-centric then you'll need a set of hub rings.
  8. Kady
    If they're off a Colorado, they won't fit on the Tahoe...
  9. choodock
    choodock New Member
    Thanks for all the advice everyone.
