What can I learn about this 2002 K2500 Suburban from this door tag?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by stephenwsmith, Oct 25, 2011.
  1. stephenwsmith
    stephenwsmith Member
    What can I learn about this truck from this door tag, I think it is a k2500 2002, with a 6 liter motor...
  2. pmf608
    There's not a lot of info on those door tags. You can take the VIN and look it up to find every detail of the vehicle, but other than that, here is what you have:
    Gross Vehicle Weight (GVWR): 8600lb
    Front Axle Gross Weight Rating (FRT GAWR): 4180lb
    Rear Axle Gross Weight Rating (RR GAWR): 5500ln
    - it meets all safety standards applicable as of March 2002
    - the original wheels are 16" with 245/75R16 tires on them.
    If you were to look at the sticker in the glove box, you would get the list of RPO codes, which indicate every feature the truck was built with. You can also get these codes by running the VIN through the GM Vehicle Inquiry System (Dealer/employee only) or entering into a site such as compnine that has a VIN decoder that will give you the RPO from your VIN and what each one means.
