What did you do to your suburban today
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by T-bone, Nov 3, 2012.
  1. T-bone
    T-bone Rockstar
    Well I changed out my water pump, T-Stat and belts. I am now officially tired
    1/2 way there
    [​IMG]
    and back on the road
    [​IMG]
  2. BBslider001
    BBslider001 Member
    Not sure why others are not responding to this thread. These are always fun.
    Well, this past weekend I completely gutted the interior, removed the carpet, front and rear, and power-washed t with a de-greaser. Looks new! I also installed new towing mirrors, changed all the fluids and replaced little bulbs that the PO had neglected. suburban 023.JPG suburban 001.jpg suburban 002.jpg
  3. dtxscott
    dtxscott New Member
    Great thread. I'm new to the site but have had my '99 K2500 for about a year.
    It had plenty of deferred maintenance so I'll re-cap what I've done over the last year (and today)
    - Front diff half-shaft output seals (L & R)
    - New brakes all around
    - Rebuilt T-case due to "Pump Rub"
    - Replaced carpet with new kit
    - Fixed leaking A/C (Main hose, receiver and evaporator..... Yes, evaporator... ugh)
    - All fluids
    This weekend I will be:
    - Re-installing the T-case
    - Motor mounts
    - Re-setting the front ride height
    - Replacing rear shocks
    I'll say one thing..... Having the factory manuals has been a life saver.
    I'm looking forward to contributing to the group
  4. Pikey
    Detailed the inside in prep for it to get trashed during the holiday road trips. I know, it does not make sense to clean it before, but what the heck, why not.
  5. NagRuTan
    NagRuTan Rockstar
    greets,
    jammed more then 2 bills for fuel into her for the holiday runs.
    nag.
  6. marko54
    marko54 Rockstar 4 Years 100 Posts
    Ordered a set of these rims for my 07 2500. This shop is local in my area. Getting them installed mon.
    [​IMG]
  7. dtxscott
    dtxscott New Member
    Got the transfer case re-installed. I then realized doing the motor mounts with the front differential in place would prove to be near impossible so I pulled the front diff and now have easy access to the motor mounts.
    I made a fixture from 2x4s that will rest against the engine block to make raising the engine easy/safe. I'll get to the mounts later this week and then re-assemble.
  8. marko54
    I still cant believe you didnt win ROTM with that Burb! Kinda makes me think what do these children look at when they vote?
  9. Pikey
    Today I changed out my front turn signal/parking light bulbs because all of the orange coating had peeled off of the old bulbs. Then I discovered that the rear turn signal socket did not want to hold bulbs anymore and they would pop out when I hit bumps. So, I repaired that also. I also decided to do the "Four High" diode mod, took all of 5 minutes. So, now my low beams stay on when my brights are on.
  10. dtxscott
    dtxscott New Member
    Got the MMs done with minimal drama. Just a PITA R&Ring the front diff. Got it all back together and driving.... Man what a difference new mounts make.
    The old ones had literally disintegrated and the mounting tube assembly was rattling around inside the clamshell.
    It fixed the vibrations I was having and things are much smoother from startup to 75 MPH.
