What does this switch do?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by ct9a, Jul 12, 2008.
  1. ct9a
    I've looked in my owners manual as well as my Hayne's manual and I have no idea what it does. It's the one below the dimmer roller.
  2. Davandy
    Davandy Moderator 5+ Years ROTM Winner 1000 Posts
    I think it's for the dome light :neutral:
  3. ct9a
    Not unless it's broken, which is possible. The only time the dome light comes on is when I turn the dimmer roller all the way up. I think it odd that the dome light doesn't come on when I open the door, so maybe.
    BTW, it's a '94 if that makes any difference.
  4. tbplus10
    On my 97 I have a button in that spot that controls the dome light. You can set it to turn on with the door opening or by using the dimmer roller.
  5. ct9a
    Maybe it IS broken then. Guess I'll have to play around with it and see. Thanks.
  6. Dan
    Dan Rockstar 100 Posts
    outside light for the bed above the rear window
  7. Opex
    Opex Member
    i had a 92 and that button was for makin to dome light come on when u open the door... so if urs dont come on when u open the door then the switch must be broke
  8. esponet
    esponet Rockstar
    its for turning off your dome light when the doors or rear acess is open.i use that switch all the time on my old burb whenever i have to carry big things and the rear hatch is open while driving. from what it looks like its in the off position. try pressing on it and open your door. see if the dome light comes on.
