What have u done to ur GM truck today? Part 2
Discussion in 'The Coffee Shop ~ Chit Chat' started by ChevyFan, Jun 7, 2013.
  1. PantheraUncia
    As I mentioned in an earlier post that caught [MENTION=51590]Pikey[/MENTION] 's attention. I have been looking at ceramic top coatings for paint to protect it in replacement of "paste wax" that is more permanent.
    Ceramic coatings are something allot of us may not pay much attention to, but they come in all grades and really are on the "cutting edge' of what regular consumers can find now.
    There are simple ones and some of the toughest ceramic coats resist salt water and are even used as ballistic grade coatings meaning they are able armor plate vehicles with them.
    Because of my schedule, I am not going to be able to apply and test this stuff on my truck for at least 2-3 months (work is keeping me busy) but I wanted to give it a shot.
    It came in from the UK and I am lucky customs did not destroy the bottles.
    [​IMG]
  2. Pikey
    Sweet. That is not the product that I had found. I am excited to see how you like it.
  3. savagetman
    savagetman Rockstar
    well did not have time this week to wire the lights so i had the local gm dealership do it for me
    tomorrow i am putting in my bedextender from amp resurch
    - - - Updated - - -
    installed amp hd sport bedextender
  4. TimTom64b
    Change my differential fluids... and greased everything
  5. Pikey
    Where did you get the alternator? Advance? I went through six of them in 2 months. I finally broke down adn bought a new bosch alternator.
    Yesterday, I installed my upgraded headlight harness. It takes power directly from the battery, has 2 relays (one for each light), is fused, and uses one of the factory connectors as the trigger for the relays. I also installed new high and low beam bulbs. For the lows I used GE Night hawk 9005, and for the highs I used Sylvania Xtra vision 9005. I was going to use the zXe bulbs but read in many places that the glare produced in poor weather was terrible. (as it was with my piaa extreme white) I did the upgraded harness for 2 reasons, 1) I have the diode mod for the brights and low beams to all stay on when the brights are turned on, I live in an area with long dark country roads so I run all four for long periods of time. I noticed that after a few minutes my headlight switch was getting warm when running all 4 bulbs, the harness stops power from running through the switch 2) I was having an issue with headlight dimming when I put up the windows or stopped and put the truck in reverse. I have a new battery and new alternator. I have checked all of my grounds. The harness stopped the dimming. I was getting 11.5 volts at the factory connector, I am getting 11.98 volts at the harness connectors.
    Today, I ordered a new AC delco air filter and an oil filter. The air filter was a pain to figure out because GM changed the part number for the "high capacity" filter for my truck.
  6. Conlan Rose
    Dis you make the harness or order it? Just wondering because I'm thinking about doing a similar thing and I don't want to mess with my factory wires.
  7. Pikey
    I ordered it. I looked around and found tons of them. Most only had one relay, so if it goes bad you loose both headlights. Mine has one for each light. Plus, if something fails it would be easy enough for me to just pull over and plug in the factory harness. I paid $30 for it. Only thing is that I wish the wires were just a little bit longer, like maybe 4 inches on each side. They are now a tad shorter than I would have liked. I will pm you the info on what I bought. I also have some questions about the big 3 upgrade you did, more about soldering the connections.
  8. reggiecab2000
    how much research did you do on this stuff???? I am very interested to see what this has to offer especially since i live on the beach.... whenever you do end up getting to it please inform us of the results!
  9. jsmith4816
    jsmith4816 Rockstar 4 Years 100 Posts
    My original is from auto zone. With the warranty it doesn't cost me anything, just the 5 minutes it takes me to take it off and bring it in. Its just a stock. I was thinking about getting a larger one, but decided not too.
    Replaced my oil filter adapter gasket so hopefully no more oil leak, or atleast a smaller one
  10. PantheraUncia
    Reggie,
    I found out about "
    http://www.zytexx.com/" (Zytexx) from a friend of mine that happened to meet the owner of the company in passing many years ago. My friend was asking me about going in with him on a franchise were we could bake it on vehicles like a properly done clear coat.
    Apparently they started another company to retail zytexx as "Proguard Plus" (PG+).
    http://www.proguardplus.com/
    They started this as a "Ceramic Glass" type coating for Yachts in the ocean and apparently added Private jets also (So they are coating Yachts and Jets).
    Then I say some photo's on their site where they coated a porsche and Harley with the stuff too. I am really interested in it as a protectant of the paint and to make those pebbles that leave chips in the hood stop. Even thinking about coating the rims with the stuff and see what happens to keep break dust from sticking.
    Unfortunately it is not good for glass (I want a permanent replacement for rain x).
    We will see what happens, again, before I put this stuff on the truck, it will have to get a proper cleaning all the way down to clay baring the paint; which I am not going to have time for any time soon.
