What have u done to ur GM truck today?
Discussion in 'Chevy Truck Talk & GM News' started by devilsalmostfree, Feb 28, 2010.
Thread Status:
Not open for further replies.
  1. Conlan Rose
    Conlan Rose Super Moderator
    Reached 200,000 miles on way to vermont :smile:
    Pics thanks to dad.
    IMG_20130524_172908_953.jpg IMG_20130524_172934_643.jpg IMG_20130524_172951_090.jpg IMG_20130524_173002_917.jpg
    Almost there....
  2. Sierraowner5.3
    Sierraowner5.3 New Member
    bought new wipers and washer fluid for it. also checked oil.
    Alex
  3. Pikey
    Pikey Moderator
    I did not actually do anything to the truck. But, my new Bilstein rear coil springs came today. So, now I can buy some Bilstein shocks and get rid of the factory Nivomat shocks. I was surprised to see that they were drop shipped directly from Bilstein. I found them for almost 1/2 the price that anyone else was charging for them. The average price was around $115, one retailer wanted $90 each, I bought them for $57 each including shipping. The markup on these things must be crazy. Now, I just need to find a deal on some shocks,
  4. Conlan Rose
    Just rerouted my new cables and added a new frame ground and starter. Also began doing my roof rack sealing. Will post pictures later.
  5. JimmyA
    JimmyA Member
    Hooked up the boat and filled both with gas! Traveling to see some boat racing tomorrow in Oklahoma.
    - - - Updated - - -
    After depressurized! Common occurrence to leak when cooled down. If you find anything get fixed soon and drive for another 100k's
  6. Conlan Rose
    Thats the plan lol. Today I fixed my leak from the roof rack the was leaking in to the cab. I'm having trouble locating the leak I think one hose clamp is leaking and possible the water pump gaskets. I also today spotted a hose that needs to be replaced asap.
  7. 95C1500
    95C1500 New Member
    Well, here is what I did to my truck today
    Wash/Wax:
    [​IMG]
    [​IMG]
    --------Check out that reflection--------
    [​IMG]
    --------My two favorite pics to date--------
    [​IMG]
    [​IMG]
    --------30 seconds after taking those pics--------
    [​IMG]
    --------45 seconds after taking those pics--------
    [​IMG]
    Didn't even get to roll up the hose :nono:
  8. SurrealOne
    SurrealOne Former Member
    @95C1500:
    Well, at least you got to watch it bead up nicely! (Pssst. You blocked out your plate in most pics but your front is showing in your first linked pic as of this writing...)
    Today I procured the following in preparation for oil system modification and initial oil fill for my York 210L compressor:
    • 10-32 taper, plug, and bottom taps
    • tap wrench
    • 10-32 set screw of 5/16" length
    • 30 weight non-detergent motor oil
  9. aloxdaddy99
    aloxdaddy99 New Member
    [MENTION=56081]95C1500[/MENTION] the only problem with pointing out the reflection is that the refelection shows a nasty 4 letter F word!! But the truck did turn out nice.
  10. SupplySgt
    SupplySgt New Member
    Changed out the U-joints a little while ago. Took just under an hour, thanks to help from my cousin and FIL.
  11. SurrealOne
    I've been paying more attention at the body shop while talking with my body man than I think he knows ... and he probably has no idea how good my memory is. Hence, I've learned a thing or two just by watching while yapping at the shop ... and it's time to apply it. So, today I ordered the following in preparation for a polishing job I intend to do next weekend (weather permitting) ... to get rid of swirl marks that my truck came with (since i bought it used):
    • Makita 9227CX3 rotary polisher/sander
    • 3M 5/8" quick release adapter
    • Three 3M foam double-sided compounding pads (05705 [white], 05706 [black], and 05708 [blue])
    • Three 16oz bottles of 3M compounds (39060 [rubbing compound for use on white pad], 30961 [machine polish aka swirl remover for use on black pad], 39062 [ultrafine machine polish for use on blue pad])
    I've eyeballed the RPM's he runs when polishing with his air polisher, and it looks like 1200-1800 is about right ... slower on the more coarse grit compounds (39060) and faster on the finer stuff (39062).
    I wanted an air polisher/sander but good ones are STUPIDLY expensive so I settled for electric (which still wasn't cheap ... but it was half the price of the air tool I wanted). I'll still wax by hand using paste because I'm old-school like that.
  12. aloxdaddy99
    [MENTION=50075]SurrealOne[/MENTION] check out the Adams Polish website. They have some video's on there that talk about buffer speed as well as other tips for using the powered polishers.
  13. JimmyA
    JimmyA Member
    Good info for later use!
  14. SurrealOne
    Today I detailed the interior of my truck to get rid of the layer of pollen that was covering EVERYTHING. As part of the effort I steam-cleaned both the carpet and the headliner. I also decided to move some things from my Du-Ha kit to the truck box to make room for long guns, again.
    @aloxdaddy99, thanks for the tip, I'll check that out.
  15. Conlan Rose
    Did a boat load of errands today also greased all the door hinges because they were creaking and I had to re tighten my starter terminal after it loosened. Good thing it came undone in the driveway not in some parking lot. I also removed the excess gasket material from the roof so it looks great :smile:. Finished my day by taking pics for a review of my Ryobi tools I'm gonna post on the site.
  16. offroadmaine
    offroadmaine New Member
    just be careful when ur buffing and keep moving never sit in one spot or you will burn through your clear coat, thats how buffing works it esentially heats up your clear coat and melts it smooth it a little more complicated then that as you know by what type of compound u bought but as a body man myself i have seen many many people sit in on spot to long and go right though there clear coat and trust me that is an ugly mark you have to repaint that part of the truck to remove. the hotter it is outside or in your shop the faster you need to move around keep an eye on the temp of your paint by touching it with your hand every once and a while.
  17. pmf608
    pmf608 New Member
    I drove my Duramax for work, as usual. Today I loaded it up with 5,600 lbs of gravel on the deck.
  18. Conlan Rose
    Drove about 180+ miles home from vermont in the truck averaged about 18-20 on the highway which is great and used the cruise about 90% of the time. Also go a new set of driving lights to replace the one I knocked off this winter.
  19. SurrealOne
    I put nearly 200 miles on the truck today, with 140ish being towing miles, as I was dragging the trailer to pick up a small riding mower on which I got a stupidly good deal.
    I also scared up a used-but-new (as in all items still in plastic) Shurhold 3101 DA Polisher Starter Kit (just like this: http://www.amazon.com/Shurhold-3101-Action-Polisher-Starter/dp/B002OIFB7S) for 40 clams, which took me a bit out of my way during the mower pick-up. Obviously I made sure it worked before paying. I'm giddy over it because I was looking to buy a DA polisher to reduce wax buffing time, next weekend and, at the price I paid, I feel like I stole this one.
    When it was time to refuel, I poured 32oz of Techron Concentrate Plus into the truck's empty 34 gallon fuel tank; I figure a little varnish clean-up might help my now-higher-mileage engine, and this is one of the few fuel additives I've read about that has a proven track record.
  20. aloxdaddy99
    [MENTION=50075]SurrealOne[/MENTION] when you are done with your truck let me know so I can drop my truck off!!! LOL
Thread Status:
