What have u done to ur GM truck today?
Discussion in 'Chevy Truck Talk & GM News' started by devilsalmostfree, Feb 28, 2010.
Thread Status:
Not open for further replies.
  1. FrigginNoodles
    FrigginNoodles Epic Member 5+ Years 500 Posts
    Hope you're enjoying the day off!
    I was going to plasti dip the bumpers that I peeled a few weeks back. Got the front done, then a friend called asking to borrow a ladder. so unfortunately the back bumpers gonna have to wait. I a, happy with the front, came out smooth.
  2. offroadmaine
    offroadmaine New Member
    changed plugs, wires, ignition coil, oil & filter, bought brake pads for the front and annoyed my neighbors with a little exhaust noise
  3. pmf608
    I took my avalanche out camping for the weekend. As usual, it did a great job of towing my quad around. The avalanche tent is great too.
  4. Pikey
    Greased my slip yoke since the shop that installed my T-case put no grease on it at all. The noise was driving me crazy. I also noticed that my brand new transfer case from GM is leaking from the front seal. Looks like it will be going back to the shop. Doing some research about replacing my shocks with bilsteins I discovered that the rear coil springs will also need replaced with a spring with a different spring rate. I found the bilstein springs from someone who ordered them and never installed them. I ordered them for 1/2 price compared to everywhere else I looked.
  5. reggiecab2000
    so does this lubing procedure really solve the horrible clunk on takeoff? (i know its temporary), but it does fix it the second you lube it?
  6. Pikey
    mine was not a clunk on takeoff. It was a horrible "Tink" sound when I put it in gear. It only happened occasionally. My 2003 did the same thing. It fixed the noise immediately. I also found a u-joint that is questionable, so I will be changing that very soon.
  7. Curky
    Curky Epic Member 5+ Years 1000 Posts
    Finished clear coat last night. I know truck needs cleaned, lol
  8. Conlan Rose
    Got a full tank of gas yesterday which made Tahoe very happy. Other than that I haven't really worked on her I just need to check the coolant level again because she is still losing coolant somewhere. I think some of the smaller hoses may be leaking and possible the water pump gasket is going. Also the Odometer as of this morning now reads 199,804.2 miles almost at 200,000 :glasses:. This weekend Tahoe is going to Vermont with me to paint some parts and fix the roof rack leak.
  9. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    Look @ the fire wall side of intake, very common for a Head Gasket to leak there!
  10. Conlan Rose
    Question are those common while running at pressure or leaking when the system depressurized. Because mine only leaks after the system has depressurized not when running.
Thread Status:
