What is the metal thing that came with the rtv sealant for?
Discussion in 'The Coffee Shop ~ Chit Chat' started by PantheraUncia, Dec 25, 2016.
  1. PantheraUncia
    I ordered the magical GM/Delco RTV sealant and the tubes came with some sort of metal thing, does anyone know what it is for? (It's at the bottom of each package. 0002.jpg
  2. Hightower
    Hightower New Member
    My guess is it's a applicator spreader/putty knife kind of deal. I know one of those never came with any RTV I ever bought.
    PantheraUncia likes this.
  3. tbplus10
    From what I can see of it through the packaging it appears to be a twist handle to put on the bottom edge of the sealant tube and roll/squeeze the sealant out evenly in a perfect bead.
    PantheraUncia and thegawd like this.
  4. thegawd
    thegawd Rockstar 2 Years 1000 Posts
    that makes sense to me TBP, and a damn great idea. these tubes almost always end up broken and all over your hands if you keep them around long enough.
  5. Hightower
    There would have to be a split in the shaft to be able to insert the flat end of the tube to use it as a twist handle. I do not notice one in the pic. That's why i'm leaning towards it being an aplicator. I was thinking the same thing at 1st. It would help to see it out the package. :)
  6. thegawd
    its damn hard to see but I do see a bent over channel on the right side that the tube would slide into. but ya seeing it out of the package would definitely help identify it a lot better.
  7. PantheraUncia
    I took it out of the package, this should give a better idea of what it is, I looked at it and it cannot fit the end of the tube, but it has a channel in it. 0006.jpg 0009.jpg 0006.jpg 0009.jpg
  8. PantheraUncia
    I think I figured it out..... the flat end of the tube goes in the slot and then the flat thing is turn the tube to squeeze all the rtv out of it so there is none left in the tube.
    thegawd, Goldie, xPosTech and 3 others like this.
  9. PantheraUncia
    It would work on a tooth paste tube also, etc
    thegawd, Goldie and kennythewelder like this.
  10. Goldie
    Goldie Epic Member 5+ Years 1000 Posts
    When the tube is empty, don't throw the "tool" away. You'll find it will come in handy for other such applications like small tubes of caulk, glue, etc. At least that has been the case for me.
