What is the preferred "best" battery for a 2002 k2500 with the 6 liter engine.
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by stephenwsmith, Oct 29, 2011.
  1. stephenwsmith
    stephenwsmith Member
    I'm looking for what you guys use here, because I figure you've been down the road before. Looks like we won the suburban, and its battery is deader than dead, so first up on the rehab is a new battery.. What do you recommend I buy?
    Stephen
  2. TRPLXL2
    I have bought 3 Optima batteries in the past five years, two yellow tops and one red top. The red top is still going strong, but both yellow tops were defective and had dead cells from the get go. A while back they had a massive problem with several batches of batteries that were bad, mine were among this group supposedly they have gotten better. But at $200+ a piece I have gone back to the Wal-Mart Ever ready batteries which do the job all the same. $49.99 for the battery in my s10 daily driver, with 5-130 watt spot lights which I use quite a bit. I usually get about 3 years out of one, so that makes me happy.
  3. Naptime
    Naptime Rockstar 100 Posts
    Another vote for Walmart. I have no valid reason other than they're near my house.
  4. ahm1127
    ahm1127 Rockstar 100 Posts
    Almost every battery is fine, just check the amps are similar to what your replacing. I would go with a dual battery, will never hurt.
  5. stephenwsmith
    Will a 8" Side Terminal/Top Terminal Battery fit my 2500 4*4 Suburban: (See Specs)
    The battery place is recommending this battery, do I have room for the height of a dual terminal battery, I frequently jump start other people so having top terminals would really be nice, particularly for a dual terminal battery if it fits?
    Stephen
    [TABLE="width: 100%"]
    [TR]
    [TD]Description:[/TD]
    [/TR]
    [TR]
    [TD="class: line"][/TD]
    [/TR]
    [TR]
    [TD="class: spacer"][/TD]
    [/TR]
    [TR]
    [TD][h=2]Deka 778DT 12-volt Ultimate Advanced Generation Battery. Group 34/78 850 CCA; 115 RC; 1020 Ref CA. 24 Month Free Replacement within 85 Month Warranty - Pro Rata.[/h][/TD]
    [/TR]
    [TR]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD]Features:[/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD]
    • [h=2]Group 34/78[/h]
    • [h=2]850 CCA; 115 RC; 1020 Ref CA.[/h]
    • [h=2]24 Month Free Replacement within 85 Month Warranty - Pro Rata[/h]
    [/TD]
    [/TR]
    [TR]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD="class: productDetailTitle"]Product Details:[/TD]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [/TR]
    [TR]
    [TD][TABLE="class: productDetails, width: 100%"]
    [TR]
    [TD="width: 30%"]Product Length: [/TD]
    [TD="width: 70%"]10.75 inches[/TD]
    [/TR]
    [TR]
    [TD="width: 30%"]Product Width: [/TD]
    [TD="width: 70%"]6.9 inches[/TD]
    [/TR]
    [TR]
    [TD="width: 30%"]Product Height: [/TD]
    [TD="width: 70%"]8.0 inches[/TD]
    [/TR]
    [TR]
    [TD="width: 30%"]Product Weight: [/TD]
    [TD="width: 70%"]41.0 pounds[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD][​IMG][/TD]
    [/TR]
    [/TABLE]
  6. silverhobey
    I agree with the Wal-Mart Enregizer Batteries .....great price, until you decide if you want
    to go with performance a few years down the road....p.s..you can probably sell you Wal-Mart battery
    later on if you decide to upgrade !!!..I can't wait to get my Crew Cab switched over to Dual-Batteries !!!
  7. ahm1127
    Should be fine, thats a good idea. Whats in there now as far as 850 CCA; 115 RC?
    You should have plenty of room for second battery, will never regret it!
  8. hotrodking86
    hotrodking86 Rockstar 100 Posts
    You know what I have a red top Optima in my car that was in that bad batch of dead cell batteries. I got a replacement and all is fine now. I have purchased batteries from Autozone and all that good stuff, same thing as those low price Wal Mart batteries to me at least. I have no problem with the Wal Mart batteries myself. My truck battery from the factory the AC Delco ended up dying at about 30,000 miles because of a dead cell. I mean all battery companies have their issues just make sure that you have enough cca's.
  9. stephenwsmith
    what does the 115 rc mean?
  10. ahm1127
    Cold cranking amps (CCA) is the amount of current a battery can provide at 0°F. The rating is defined as the amperage a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery).
    Reserve capacity minutes (RCM), also referred to as reserve capacity (RC), is a battery's ability to sustain a minimum stated electrical load; it is defined as the time that a lead-acid battery at 80°F (27°C) will continuously deliver 25 amperes before its voltage drops below 10.5 volts.
