what kind of oil?
Discussion in 'General Chevy & GM Tech Questions' started by wallstetter, Oct 20, 2008.
  1. wallstetter
    wallstetter Rockstar ROTM Winner 100 Posts
    wondering what kind of oil everyone runs right now im running amsoil synthetic but its exspensive and kind of hard to get your hands on it around here
  2. 04sierracrewcab
    i switched to synthetic last week I put in Royal Purple $ w a kn oil filter
    but prior to that It only got Penzoil :)
    got them both from my local Orilley Auto Parts
  3. scooby2b2
    scooby2b2 New Member
    Synthetic oil
    I use the Mobile One Extended which says its good for 15k or one year but change every 5k to 7k miles.
  4. retired2001
    I'm also running Royal Purple, but Mobil 1 is very good and a little less expensive.
  5. MWright936
    I started using Royal Purple, then decided to switch to Mobil 1 to save a little coin. I've been happy with both.
  6. Springthing
    After reading the great posts here I'll be doing Mobil 1 and changing every 7500 - 10,000 miles depending on whether I've done any towing or heavy work.
  7. zach45
    zach45 Epic Member 5+ Years 100 Posts
    every 5 k..
    castrol syn.
  8. bry2500
    I just did my oil change and used Quaker state full sythetic horsepower & torque formula. So far I like It I have always used Mobil 1 in my vehicles but figured I would try this one in my avalanche. It runs around the same price as Mobil 1.
  9. SilveradoBrett
    SilveradoBrett Rockstar
    I run mobil in everything I own except the yamahas that I guess are supposed to have the "special" $20 a quart of racing oil. But it only takes a quart so I don't complain about that. So I used to run penzoil all the time, swore by the stuff. But when it came time to rebuilt the ford motor there was so much gunk on the valves that it was just plain gross. I thought it was normal and then a few months later I helped a buddy rebuild an old 351W that had been using mobil forever. After comparing the gunk build up on the two valves I made the switch to mobil. I even use the lubricant for my guns, the stuff is great and not too expensive. However every once in a while castrol full synthetic is on sale at vatozone (not autozone where I live) so I get that. Both are great, but for the most bang for your buck I have found that mobil extended is the best deal. Also you can buy it at walmart while you are buying your clothes! Pretty sweet!
  10. chevyman5.3L
    chevyman5.3L New Member
    I have been running castrol syn and change every 5000miles for 6 years in my truck and its good stuff. I run my truck pretty hard. I run pennzoil (not syn) in my 08 malibu and thats pretty good stuff.
