what kind of ring and pinion setup do i need
Discussion in 'GM Powertrain' started by 1996k1500, Apr 26, 2010.
  1. 1996k1500
    1996k1500 New Member
    i have a 1996 k1500 4wd i want to change the ratio in the rear to 4.56 what ratio do i need to put in the front to make it right
  2. MrShorty
    Unless there's something you aren't telling us, you need 4.56 in the front as well.
  3. Big75
    Big75 Rockstar 4 Years 500 Posts
    a common misconception is that the front is geared different so that it pulls the truck in 4wd. I've heard this one too. you should have the same gears front and back.
  4. Big75
    4.56 is pretty low, how big are your tires?
  5. 1996k1500
    35/14.50x15 nitto mud grapplers i want the truck to pull like crazy in 4lo but still do ok on the street
  6. Silverado1500
    Silverado1500 Rockstar 100 Posts
    for a 1500 isnt it recommended that you dont go higher then 4.56s? correct me if im wrong
