what offset wheels can i run on my 08 silverado
Discussion in 'Lifted & Offroad Suspension' started by rodeo072003, Aug 27, 2011.
  1. rodeo072003
    rodeo072003 New Member
    hey guys i am so confused .i am putting a readylift leveling kit on my truck and want new wheels and tires but i dont want any rubbing ..i am really intersted in the fuel hostage wheels but there are like 3 or 4 offset options ..any input wuld be awesome and thanks
  2. Rockstarrchevy81
    Rockstarrchevy81 Rockstar 3 Years ROTM Winner 1000 Posts
    I also am looking at the Fuel hostage but with the readylift a -44 offset and -24 that they have i believe will nto work on your truck. The only ones that could work are the 20x9 and such nothing over a x9 such as a x10 or x12 will NOT work they are too wide and offset and backspacing will make it rub really bad when you barely turn. You will need a 6 inch lift or more to run a 20x10 or 20x12 will need even more. I would try to find a rim 18x9 or 20x9 with a 0 offset but stay away from the ones that have a really high Negative - offset!
    Tires you can run a 33 but will be narrow like a 11.50 without rubbing hope this helps some man!
  3. ajarman
    A 33" tire on a 0 off set wheel will not fit on a leveled NNBS with out cutting. Look for something in the +18 - +28 range which will be close to stock off set.
  4. Rockstarrchevy81
    The Fuel Hostage 18x9 and 20x9 come in +20 offset which would be the bst one to go with. All the other's are pretty much Negative- Offset and none are 0 offset. A Narrow 33 and either 18x9 or 20x9 with +20 offset will work. The a good website to buy from is www.rimzoneonline.com you can find them there!
  5. rodeo072003
    thanks alot guys that helps alot and yes i was looking at the 18x9 ..i belive i will go with the +20 ..and i will probbaly just run some 285/65/18 nitto terra grapplers..i hope it will look good. now all i gotta do is sell mine but agian thnx guys..ajarman always has the answers
