What Size Rear Do I Have
Discussion in 'Maintenance & Upkeep' started by davedyno, Jan 31, 2014.
  1. davedyno
    davedyno Member
    What size rear, what Trans do I have. I would like to order on line like GM Part Direct. I gave them my Vin # they say rear cover gasket has 14 Holes, I count 10 Holes.
    I would like to order Trans Filter, Pan Gasket, rear end cover gasket.
    2011 Silverado Ext 4X4, 5.3, Z71,Z85 Pkg, 6 speed auto,trailering Pkg,Trailer Brake Controller, 18" Wheels
  2. Dana W
    Sorry, I can't really help you but the title of your thread made my day a little better. I am still laughing a little now.
    Dave, on your Trans.....it is the 6L80e 6-SPEED AUTO/TRANSMISSION, the RPO Code is "MYC"......and with Counting 10-Bolts, your Rear Diff would look like this one below.
    The GM 8.6" Rear, '09 & Up. Has 10 Bolt Cover and 30 Spline C/Clip Axles.
    Ring Gear Diameter: 8.500
    Cover Bolts: 10
    Ring Gear Bolts: 10
    Spline Count: 30
    Dropout: False
    Pinion Support: False
    Carrier Breaks: 2.56 / 2.73
    Rear Suspension: Solid
    Pinion Nut Size: 1-1/4
    Link/for Rear Diff Information
    Dave go to the Link Below, and Enter your Trucks Vin #Number, and it will show you everything it Came with from the Factory, along with the all of the RPO Codes.
  4. McClintoc
    Did you buy your truck new or pre-owned? If new, do you still have the window sticker? See if it says on there what rear end you have.
  5. davedyno
    davedyno Member
    Thanks 99' HEARTBEAT. Great information
    - - - Updated - - -
    After I read my own post, I see what you mean. I'm laughing too.
    - - - Updated - - -
    I still have window sticker, it say's rear axle 3.42, locking rear differential. 99'HEARTBEAT have the info I needed.
    Also Inside your Glove Box is a White Tag/Sticker....which is the Service Parts I.D. Tag(Pictured Below)and on it you will see your Vehicles Vin # Number and a Series of Letter's and Number's which are RPO Codes.....which stands for Regular Production Options...In Short its what your Vehicle came with from the Factory,
    the Service Parts Identification Label
