What size tires?
Discussion in 'Wheels & Tires' started by Chevyman224, May 3, 2009.
  1. Chevyman224
    Chevyman224 Rockstar 100 Posts
    Ok i have 18x9 wheels and idk what size tire to get. I want 33s. Should i get 275/70/18s or 325/60/18s or 33x12.50. Idk which would be best or what would fit better with a leveling kit. Any recommendations?
  2. Pete95Sierra
    go with the 33/12.5. the 275's are too small and the 325's will be too wide
  3. Chevyman224
    ok thankks!
  4. NoelZ71
    NoelZ71 Member
    the 325/60R18's are the same as a 33x12.50R18. I have 275/70R18's on mine and they dont rub. the only difference between the two is the width. they are the same height. I have some 325/65R18's that I put on which is a little taller and wider than what I had before, but they rubbed on the back of the inner fender wheel so I ordered some leveling keys and I Will put them back on after I put the kit on. On most of the XDs they have low offsets. If that is what yours are the 325's might still rub a little. 275's wont be any problems with out losing any height. If your wheels have a +15 offset or more the 325's will probably work without any rubbing. Some people dont mind the rubbing, so its up to you and the way you want them to look.
