Wheel Backspacing?
Discussion in 'Lifted & Offroad Suspension' started by ntbush83, Oct 7, 2010.
  1. ntbush83
    I've always been a bit confused on the back spacing and offset on wheels. I'm looking at getting some 20x10 wheels and not sure what offset the wheels should be. I'm planning on putting on a 325/60/20 tire if that makes a difference. Anyone know much about this?
  2. stephan
  3. ntbush83
    Thanks that did answer all my questions! That was a freakin sweet diagram
  4. 99'HEARTBEAT
    Backspace and Offset are tied together
    Measuring Wheel Offset To calculate offset you'll need the following measurements:
    .......Wheel backspace Wheel Width Wheel Center line (outboard flange to inboard flange measurement.
    ......Wheel center line from Wheel backspace to get offset......If backspace is less than the wheel center-line the offset is negative....If backspace is greater than the wheel center-line the offset is positive.
    [​IMG]
    [​IMG]
    On the Below Link.....On the Left Side,you want to enter your Rim and Tire Size you have on your truck Now......and then on the Right Side enter your Rim and Tire Size,
    It will show you the difference from your Stock Rim & Tire Set-up,to the Rim & tire set-up you want to put on,
    http://www.rimsntires.com/rt_specs.jsp
    Edit....Sorry Stephan,While I Was writing-up my reply....you had replied,did not mean to do that.....:glasses:
  5. stephan
    I saw that same article in a Super Chevy mag about 6 years ago, but loaned it to my friend & never got it back so was happy to find it here at GMTC.:great:
    ---------- Post added at 02:23 PM ---------- Previous post was at 02:16 PM ----------
    No Worries Heartbeat
    I am such a slow typer that many times there are 2 or 3 posts appear while I am typing my answer.:lol:
    [/FONT][/QUOTE]
