Wheel Hub
Discussion in 'GM Powertrain' started by bzboardco, Jan 29, 2009.
  1. bzboardco
    bzboardco Rockstar 100 Posts
    My 02 Silverado is beginning to sound like it has mud tires on the front...could this be the wheel hub assy? I have checked the tires for cupping and damage etc. I couldn't find anything wrong plus they are fairly new.
  2. MrShorty
    That's the first thing I think of. I might jack up the front end and rotate the wheels by hand to see if I could hear/feel the grind while I'm in a position to pinpoint where the sound is coming from.
  3. mjalstad
    mjalstad Rockstar 100 Posts
    When you're driving, if you turn does the noise go away or lessen? If so, it needs a hub. Also if you jack it up, put one hand on the top of the tire and the other one on the bottom and wiggle it and feel play in it, you need a new hub.
  4. vncj96
    After you get home from work or whatever get out and just put your hands on the center of the wheel it should be cool but if you can feel any heat then they are starting to go
  5. bzboardco
    Thanks guys...The noise does stop when I turn left around a curve and there is play in the wheel. :grrrrrr:
