Discussion in 'Chevy C/K Truck Forum' started by 1500/Camaro, Dec 28, 2010.
  1. 1500/Camaro
    1500/Camaro New Member
    I wanted to know what the highest year of wheels i can put on my 1995 1500 i wanted to know if after 2000 will the wheels still fit if i put them on my truck
  2. murdog94
    Model would help since there are two differnt rims available for the 1995 the set for 2wd, and the set for 4wd.. in 1999 they went to a 6lug rim for both but 1988-1998 had a 5lug for 2wd, and 6 lug for 4wd.. but if it is a 4wd anything from 1988-2009 and mabey later will bolt right on.
  3. pychokenny
    pychokenny Rockstar 100 Posts
    if it is a 4x4 it be from 1960-2011 it if is it a 2wd it be 1973-1998
    Only up to 1999 !!!!!!! the one u have hub ecsentric and have a smaller hub then the newer ones !!
  5. murdog94
    They will work just fine. I had 2007 rims on my 1988, and my 1998 Chevy truck.. You cannot take the rims off of say a 1995 and put them on a 2001. You will need to have the proper lug nuts that center themselves... As long as you use the lug centric lugnuts then you are fine..
    As i said you can take the rims from a 1999 up and put them on the older body style you just cant take the older body style rims and put them on the new body style.
  6. pychokenny
    is it a 2wd or a 4x4
  7. 98regcab
    98regcab New Member
    i have 00+ rims on my truck and its a 98. im not sure what the year the rims are from but my dads 03 tahoe has them
  8. 1500/Camaro
    well i have 1995 z71 4x4 so from what everyone is saying anything to 2009 will fit that is coolbeans thanks guys
