Where's my fuel filter at?
Discussion in 'Performance & Fuel' started by 178kchevy, Mar 25, 2009.
  1. 178kchevy
    178kchevy Member
    My truck is a 95 K1500 ext. cab. I want to replace my filter, but I don't know where it is. I hope you don't tell me it's INSIDE the gas tank! But, if anyone knows, please let me know.
  2. GaryL
    Should be on the frame rail under the truck. Follow the lines back from the tbi and you will find it.
  3. jlh0324
    jlh0324 New Member
    It should be right below the drivers side door, behind the truck frame. That's where my 93 had it and my 03 has it in the same spot. Just note "out" in the filter is towards the engine.
  4. Z71_guy
    it will be on the drivers side inside the frame rail, just above the t-bar kind of sob to get to not much room to swing a wrench
  5. norcalbear05
    norcalbear05 Rockstar
    ditto on being a bitch to get to! with my meat cleavers i got busted knuckles trying to change out mine lol
  6. FireRed
    FireRed Rockstar 100 Posts
    It will save some blood loosening the fule line clamps so you can pull it and the lines away from the frame enough to get the linesin/out, there is -0- to and froe motion. It is easy to screw up the fittings or filter if you don't take your time.
  7. norcalbear05
    Thanks ill keep that in mind next time.
