Wierd DTC
Discussion in 'GM Powertrain' started by rileyjr16, Sep 10, 2013.
  1. rileyjr16
    So I'm in the process of doing a mpg test on my truck on the different octanes and octane tunes. Well today when I switched from 93 octane to 87 octane, my programmer said my truck is throwing 5 codes. 2 of them being U1026 and U1041. NO idea as to what these codes are referencing as they are not in my Haynes book. Kinda clueless on this one.
  2. Pikey
    I found this with a quick google search, it is not my work, but may help.
    DTC U1026 Loss of ATC Class 2 Communication
    Circuit Description
    Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring (Node Alive messages). A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that module's "Node Alive" message. Each module on the class 2 serial data circuit which is powered and performing functions that require detection of a communications malfunction is required to send a "Node Alive" message every two seconds. When no message is detected from a learned identification number for five seconds, a DTC U1xxx (where xxx is equal to the three digit identification number) is set.
    The Control Module ID Number list provides a method for determining which module is not communicating. A module with an internal class 2 serial data circuit malfunction or which loses power during the current ignition cycle would have a Lost Communication DTC set by other modules. The modules that can communicate will set a DTC indicating the module that cannot communicate. When no message is detected from a learned identification number for five seconds, a DTC U1xxx (where xxx is equal to the three digit identification number) is set.
    Control Module
    ID Number
    ATC
    026
    BCM
    064
    EBCM
    041
    EVO
    192
    IPC
    096
    PCM
    016
    SDM
    088
    VCM
    016
    VIU
    016
    When more than one Loss of Communication DTC is set in either one module of in several modules, diagnose the DTCs in the following order:
    Current DTCs before history DTCs unless told otherwise in the diagnostic tables.
    The DTC which is reported the most times.
    From the lowest number DTC to the highest number DTC.
    Conditions for Running the DTC
    Voltage supplied to the module is in the normal operating voltage range (approximately 9 to 16 volts).
    Diagnostic trouble codes U1300, U1301 and U1304 do not have a current status.
    The vehicle power mode (ignition switch position) requires serial data communication to occur.
    Conditions for Setting the DTC
    A messsage from a learned identification number has not been detected for the past five seconds.
    Conditions for Clearing the DTC
    A current DTC will clear when a "Node Alive" message from the failed identification number is detected on the class 2 serial data circuit or at the end of the current ignition cycle.
    A history DTC will clear upon receipt of a scan tool "Clear DTCs" command.
    Test Description
    The number(s) below refer to the step number(s) on the diagnostic table.
    A module which loses power during an ignition cycle will cause other module(s) to set Lost Communication DTCs.
    The malfunction is due to an open in the class 2 serial data circuit or an open in the module.
    The module which was not communicating may have set Lost Communication DTCs for those modules that it was monitoring.
    The modules which can communicate indicate the module which cannot communicate. You must clear the DTC from these modules to avoid future misdiagnosis.
    Step
    Action
    Value(s)
    Yes
    No
    1
    Test the battery positive voltage circuit(s) of the module that is not communicating for an open or a short to ground. Refer to Control Module References for the applicable schematic. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
    Did you find and correct the condition?
    Go to Step 9
    Go to Step 2
    Turn OFF the ignition.
    Test the ground circuit(s) of the module that is not communicating for an open. Refer to Control Module References for the applicable schematic. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
    Go to Step 9
    Go to Step 3
    3
    Disconnect the scan tool.
    Test the class 2 serial data circuit for continuity. Refer to Testing for Continuity in Wiring Systems.
    Go to Step 7
    Go to Step 4
    4
    Test the class 2 serial data circuit of the module that is not communicating for an open between the module and pin 2 on the Data Link Connector (DLC). Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
    Go to Step 7
    Go to Step 5
    5
    Inspect for poor connections at the battery positive voltage circuit(s), the ground circuit(s) , and the class 2 serial data circuit of the module that is not communicating. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
    Go to Step 7
    Go to Step 6
    6
    Replace the module which is not communicating. Refer to Control Module References for the appropriate repair instructions.
    Did you complete the replacement?
    Go to Step 9
    7
    Install a scan tool
    Turn ON the ignition leaving the engine OFF.
    Select the Display DTCs function for the module which was not communicating.
    Does the scan tool display any DTCs which do not begin with a "U"?
    Go to Control Module References or the applicable Diagnostic System Check
    Go to Step 8
    8
    Use the scan tool in order to clear the DTCs.
    Did you complete the action?
    Go to Step 9
    9
    Select the Display DTCs function for the module(s) which had the Lost Communication with xxx DTC set.
    Go to Step 10
    10
    Continue diagnosing or clearing the DTCs until all the modules have been diagnosed and all the DTCs have been cleared.
    System OK
  3. rileyjr16
    Holy Krakatoa... So what modules are we referring to? ATC and EBCM. Which is?
  4. Pikey
    If everything is working properly I would bet that it was just a communication issue with your programmer. I have sent you a PM with a link to some better info that I found.
    Transfer Case Shift Control Module w/4WD= BCM U1026
    Electronic Brake Control Module= (EBCM) U1041
    Maybe [MENTION=39185]j cat[/MENTION] will see this and help out. He never ceases to amaze me with the knowledge that he has about this kind of thing.
