Will a 265mm Tire it on stock rim?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Bowtied, Nov 23, 2013.
  1. Bowtied
    Bowtied Epic Member 5+ Years 500 Posts
    Hi guys my stock wheel has the 255/70/16 tire on it, would a 265/70/16 tire fit?
  2. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    Yup. I'm guessing someone put smaller tires on it. 265s are the oe recommended size but a lot people go to the 285/75 that should be the biggest you can go with out rubbing( at least without any lift) on a 4wd. If yours is 2wd you probably don't wanna go any bigger than the 265 without doing a little research first.
    These should be a sticker inside your driver side door jam with the recommended size a tire pressure
  3. 99'HEARTBEAT
    clgoch187......The 255/70/16's was one of the Tire Sizes that Chevy/GM Installed on the Factory 16in" Alloy Wheels.
  4. BurbanMan
    BurbanMan Member 1 Year 500 Posts
    ^this is accurate. You can actually fit as big as 265/75/16 on your truck if it's 4wd, maybe even on 2wd
  5. BurbanMan
    285/75 requires a leveling kit at the very least without rubbing.
  6. 99'HEARTBEAT
    To help you, here's some Information"Specs"on both Tire Sizes, the 255/70's and the 265/70's....
    255....Overall Diameter of....30.1in" and the Section Width is 10in"
    265....Overall Diameter of.....30.6in"and the Section Width is 10.4in"
  7. clgoch187
    I had 185/75/16s on my or wheels with absolutely no rubbing on my 03 z71 before I leveled it and from what I can find the z71 suspension package had no change in ride height.
  8. BurbanMan
    Z71's are taller than the regular 4x4. Although, I wouldn't expect a 185 to rub on a geo metro. Let alone a z71 lol
  9. thrasher
    thrasher Rockstar 100 Posts
    I have 285/70r16's on my 2001 HD2500, no rubbing issues...
  10. BurbanMan
    those are almost the same height as a 265/75/16. They're just wider....
