Will a 265mm Tire it on stock rim?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Bowtied, Nov 23, 2013.
  1. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    285 sorry. And my truck next to my buddys 06 1500 ls the bed rails handles fenders etc are all about level...except of the front edge of the hoods of course due to the newer style hood
  2. Bowtied
    Bowtied Epic Member 5+ Years 500 Posts
    Another question I was wondering, I noticed that one "available" size for my tires, after looking online, is a 235/75/16, will THIS fit on the factory rim? and also would getting a "thinner" tire give me better gas mileage?
  3. BurbanMan
    BurbanMan Member 1 Year 500 Posts
    how wide is the factory wheel? I certainly wouldn't run it as your truck probably isn't calibrated (gears, speedo) for such a short tire
  4. 99'HEARTBEAT
    Yes, the 235/75/16's will fit.....and as far as Better Fuel Mileage with a thinner tire.....in looking(Below)at both Tire Sizes, the 255/70's that you have on Now Vs the 235/75's....as you can see there is very little difference between them, by chance do you on what Gears your Truck Has??
    [TABLE="class: withlines, align: center"]
    [TR]
    [TD="align: center"]Tires:[/TD]
    [TH]Tire 1[/TH]
    [TH]Tire 2[/TH]
    [/TR]
    [TR]
    [TH]Tire Size
    [/TH]
    [TD="align: center"]255/70-16[/TD]
    [TD="align: center"]235/75-16[/TD]
    [/TR]
    [TR]
    [TH]Section Width
    [/TH]
    [TD="align: center"]255 mm (10'')[/TD]
    [TD="align: center"]235 mm (9.3'')[/TD]
    [/TR]
    [TR]
    [TH]Sidewall[/TH]
    [TD="align: center"]179 mm (7'')[/TD]
    [TD="align: center"]176 mm (6.9'')[/TD]
    [/TR]
    [TR]
    [TH]Tire Diameter
    [/TH]
    [TD="align: center"]764 mm (30.1'')[/TD]
    [TD="align: center"]758 mm (29.8'')
    6 mm (0.8%) shorter.
    [/TD]
    [/TR]
    [TR]
    [TH]Rim Sizes[/TH]
    [TD="align: center"]16x7 to 16x9.5[/TD]
    [TD="align: center"]16x6 to 16x9[/TD]
    [/TR]
    [TR]
    [TH]Circumference[/TH]
    [TD="align: center"]2399 mm (94.4'')[/TD]
    [TD="align: center"]2380 mm (93.7'')[/TD]
    [/TR]
    [TR]
    [TH]Revs Per Mile
    [/TH]
    [TD="align: center"]670.8[/TD]
    [TD="align: center"]676.2[/TD]
    [/TR]
    [TR]
    [TH]Speedometer[/TH]
    [TD]Assuming that this is OEM Tire and Speedometer Readings are Correct >>>[/TD]
    [TD]When Speedometer Reads 60mph...Actual Speed will be 59.5mph: 0.8% Slower.[/TD]
    [/TR]
    [/TABLE]
