Will not start, and will go into reduced engine power
Discussion in 'GM Powertrain' started by BIGREDDADDY53, Sep 12, 2012.
  1. BIGREDDADDY53
    BIGREDDADDY53 Epic Member 5+ Years 100 Posts
    First started with the battery and last time it went into reduced power mode. Does this kinda thing happen when youu charging system is not working. Doès any have any tipsÉ
  2. rileyjr16
    To help more with your problem, you could give us your truck make, model, engine.
  3. Pikey
    @BIGREDDADDY53 , you started a thread about this yesterday, if you keep all the info on the same thread it may help us help you. As stated in the thread you started yesterday by a few members, you need to have the battery checked and codes read. If the battery passes the test, then hopefully the codes can help lead us in the right direction. As stated on the other thread, reduced engine power mode can be caused by many things. One of the most common, the throttle body motor or the connections going to the tb motor.
    http://www.gmtruckclub.com/forum/sh...was-giving-me-alot-of-probvlems#axzz26JoJCdDD
