Will they fit?
Discussion in 'Lifted & Offroad Suspension' started by MD4x4 Fireman, Jul 26, 2008.
  1. MD4x4 Fireman
    MD4x4 Fireman Epic Member 5+ Years 1000 Posts
    I am gonna be given a set of 33" tires. Will they fit? My truck is bone stock as far as suspension, the make/model are in my sig. Also how do I fix my speedo so it reads the right speed.
  2. Pete95Sierra
    i think they will fit but will rib on the stock rims. they may look pretty stuffed in there too. and you need to get a new speedo recalibrator to get your speedo right. i think superlift makes one
  3. 383man
    383man Epic Member 5+ Years 500 Posts ROTM Winner
    they might actually rub, i have a 6 inch lift and my 35/13's still rubbed till i cut out the fenders some. if you get a leveling kit you should be able to do a little bit of easy cutting on the front and be alright, the back will fit though.
  4. tbplus10
    87's had big wheel wells, some of the biggest GM ever made, stock with the factory suspension they'll rub some (depending on how much your suspensios sagging), but if you put new stock height springs they should fit for around town.
    Off road you'll need a couple inch's of lift.
  5. MD4x4 Fireman
    ok, i think i might put them on and PRAY. Now all I got to find the thing to fix how off my speedo will be.
