Window Motor crapping out????
Discussion in 'GM Electrical Tech' started by TELORVEHC, Nov 3, 2010.
    This has been an issue since I first got the truck, the previous owner had aftermarket power windows installed, and the passenger side power window is considerably slower raising and lowering than the driver side. I'm guessing the power window motor is shot? Also, I notice that when I raise/ lower the passenger window at the same time as the driver side window, the passenger window raises/ lowers slower than if it were raised/ lowered on its own, not sure if that compounds the issue or not. If it is the window motor, would this be the part I'm looking for?
    Thanks y'all
  2. sstoner911
    You may want to pull the door panel off and see whats in there if you havent already...when your dealing with aftermarket components like those you never know what it is or if that exact part can be found/replaced.
