Windshield washer fluid won't flow
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by kdogusa69, Dec 15, 2010.
  1. kdogusa69
    kdogusa69 New Member
    2009 Silverado
    Wipers work fine but twist the lever for fluid and none comes out. Any ideas? And yes, i added wiper fluid. In the correct tank.
    Is it possible a hose is disconnected that goes to the washer fluid tank? I looked but couldn't see where it went once inside engine compartment. Point me in any direction?
    Thanks.
  2. mfleetwood
    Do you hear it trying to pump the fluid? If not, check the fuse. If the pump is working and you don't notice any fluid coming out, a line could be plugged someplace. If the pump is working, I would also check to see if the fluid level drops after letting it run for a few moments....if it drops, then it sounds like you have a leak or the hose disconnected.
  3. Bigbomber
    I had this problem on my Uplander,found a hose disconnected but still didn't have any fluid coming out.Couldn't hear the pump and no burnt fuse so the dealer ordered a replacement,luckily its not going to cost me any money because its still under warranty.
  4. mfleetwood
    Interesting..I wonder if the system somehow loses pressure from a disconnected hose and it keeps the pump from pumping? Did the dealer mention what happens when the hose disconnects? Also, was it the hose the dealer replaced or the entire unit? In any case, glad it was under warranty.
  5. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    You live in cold climate? Perhaps water got into lines and it is frozen. ?
  6. kdogusa69
    I do live in Northern Michigan but since the last time i used the windshield washers i don't think its gotten warm enough to get water in the lines i wouldn't think. Gonna check in the morning if there is a fuse for the washer pump because when i twist the wiper lever i hear no noise like the washer pump working so hopefully that will be it.
  7. mfleetwood
    Let us know what you come up with....interesting problem.
  8. kdogusa69
    Will do. Thanks for the thoughts.
    After looking through the online owners manual, looks like there is a fuse for the front washer pump (under hood #7). So we'll see what happens when i swap out that fuse.
  9. Bigbomber
    He didn't say what happens when the hose disconnects and they replaced the whole unit.
  10. mfleetwood
    Thanks Bomber!!
