Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by billlp, Dec 28, 2008.
  1. billlp
    billlp New Member
    Hi I have a 99 3/4 ton sub that has a problum with it's wipers. When I use the intermittent feature of the wipers the stroke gets interrupted and stops,sometimes for quite a while then it finishes the stroke. The longer I use them the better they get. Any ideas what to replace.
  2. Springthing
    My guess is the wiper control module.
  3. JMoney02
    Yes, printed circuit is wearing out......As it warms it functions better, replace like Springthing stated.
  4. billlp
    billlp New Member
    Thank you
  5. billlp
    billlp New Member
    Thank you
  6. jim1958
    jim1958 Member
    I agree with control module, however I haven`t seen it be the printed circuit board. I`ve seen it be the two metal contact tangs and the ball wears off the ends of them. Thus no electrical current because no contact. Take the screws out , pull off and bend the tangs out a bit and a little die-electric grease put it back together and see if you didn`t save yourself $100.00
  7. vncj96
    That old could also be the actual blinker switch going, all that time and twisting the arm for the wipers on and off
  8. mrfixdit
    mrfixdit Rockstar 100 Posts
    check for any recalls on this I had one on my 97 Silverado they took care of it no cost.
  9. billlp
    billlp New Member
    Thanks for the info it worked great at least for now. That little ball is verry flat at this point. On my burb the tangs are part of the circuit board. I will just see how much longer it will work It's allways good to save money.
  10. jtwh20
    jtwh20 Member
    Is the control module under the hood, or in the steering column?
